frequency-dependant resistor
farshaddd
Newbie level 5
Newbie level 5
Hi Every one
On the following page, I found a solution for frequency controlled resistor.
would you please help me with these questions? Thanks a lot
1: How can I bring a block named as Z1P_Eqn?
2: There is a block on the top right side of the figure below. How can I bring that?
Regards, Farshad
You can find the Z1P_Eqn under the palette "Eqn Based-Linear". You can also write directly the name of the block you want (in your case Z1P_Eqn) in the entry box placed between the menu and the palette then press enter and when you will move the mouse in the schematic windows the block will be available to be placed.
