neazoi
Advanced Member level 6
Hi, I have found this circuit https://www.qsl.net/pa2ohh/pccnt.htm
It uses a very simple schematic and DOS software (not a problem for me) to count.
I do not know which of the two methods it uses for frequency counting but it has a good resolution and variable gate time on the software side, plus it can count to 80MHz whereas most microcontroller counters can count to 50MHz without a prescaler.
It also accepts an external reference frequency which is good because an OCXO or a GPSDO can be used.
I would like your comments on it, the pros and cons you can see.
What if I would like to make it sinewave compatible, shall I include a broadband amplifier at the input and just led the clipping diodes do the swuaring job, or better include a schmitt trigger?
