The actual way of doing with L and C is as follows.
Here the capacitor allows the ac signal and to flow through the OPAMP and evaluates the (gain & Phase response) stability response...the inductor blocks the AC signal coming from the Source. At the other end of the inductor u find the ac signal. from the Ac analysis find the Gain response from output to input and u will get the similar response as that of the stb analysis.
to get the Stability response keep high values of L and C...
We only want the DC portion of the output to go to negative terminal, so that the op-amp is properly biased. So we use C and L to send only dc portion in feedback. And then we can apply the ac voltge seperatly on inegative terminal, to see the gain on the output.
