danny davis
Banned
When a transistor is an amplifier it will drift the voltage up or down when you freeze or heat it up, does this mean its bad or good?
When a transistor is a switch , it will drift the voltage up or down when you freeze or heat it up , does this mean its bad or good?
When resistors are temp failure, the resistance changes up or down depending on the freezing or heating it up
At work i had to do freezing spray and heating up these OP AMPS that were in the shape of a metal can transistor looking types like a IC chip package type, I had to freeze spray and heat them up ONE by ONE
But I can't tell if the transistor or these Op amps are good because the voltage will go up or down
