Free RTOS for LPC2366
devendra_devgupta
Member level 3
Member level 3
freertos lpc23xx
Dear friends
I am developing an application using LPC2366. I have finished the driver part and now i have decided to use some multitasking in my program. Can some one suggest me a RTOS which is free (fully) and can be used with keil / ARMCC compiler.
I have seen Freertos but it does not support LPC23XX in keil / ARMCC compiler
Please help me
Thanx in advance
devendra
lpc2366
My knowledge in this field is limited.
But I suggest you go to freertos.com
lpc23xx compilers
devendra_devgupta said:
Dear friends
Please help me
Thanx in advance
devendra
Doesn't the Keil toolset already come with some sort of task-switcher? I forget what it's called, something like RTX? Will that do what you need?
lpc2368 rtos can
Hi devendra_devgupta,
Yes, as SmartBomb1979 rightly said, Keil comes with an inbuilt RTX kernel.
You will get almost all the functionalities of a good scheduler in this. This can be easily fit into many applications that require task switching. The support for this also is good from Keil.
Regards,
vhn
keil freertos lpc2368
You people have really helped me
I will try out this, and will ask if i have any doubt in this
Thankyou
I can port neither Freertos nor RTX for lpc2366.
If anyone has succesfully ported, is it possible to share core settings or tips in here.
Thank you.
FreeRTOS can be ported on LPC2366. There is a port already for LPC23xx but working with GCC.
I guess after facing some compilation errors, you will be able to run it with KEIL.
Amr Ali
I prepared a working rtx template for 2368 and keil. If anyone needs could download from **broken link removed**
