MarkSitkowski
Newbie level 3
If you're old school, and like SPICE, here are some tools that might interest you (Sun SPARC or Linux only). They're totally free, with no licence fees or restrictions.
Go to designsim.com.au/analog.html, and download as much as you want:
Graphical circuit design tool
SPICE simulator graphical interface and DSP post-processor
Waveform calculator DSP functions include:
FFT (mag/phase or rela/imag)
IFT (mag/phase or rela/imag)
Convolution
Deconvolution
Differentiation
Integration
Arithmetic functions
Reverse-engineering tool to generate graphical diagram from SPICE netlist
Netlist compiler from graphical diagram to SPICE netlist
SPICE parameter extraction tool from characteristic curves
Component libraries, including
About 800 SPICE2/3 models of semiconductor devices
Full set of Laplace Transform primitives for high level design
Op-amps
Comparators
Magnetic components, transformer cores, in metal and ferrite
Mechanical components, including motors, geartrains,
primitives such as slip, friction and inertia
Opto-isolator library
All the common TTL/LSTTL gate functions, by type number
Macro-models of:
A to D converter
Analogue switch
Binary code generators
D to A converter
FET analogue switch
Transparent Latch 4 bit
Voltage/current limit (bilateral)
Superdiode limiter (comparator)
Transmission line oscillator
Pulse generator
Pulse-width modulation transformer
PLL error amplifier
PLL phase detector
Series regulator 1
J3 SCR macromodel
SG1524 switch-mode power supply controller macromodel
Sample and Hold/Track and Hold
Voltage-controlled Oscillator
Convolution
Deconvolution
Differentiation
Integration
Op-amps
Comparators
Macro-models of:
A to D converter
Analogue switch
D to A converter
FET analogue switch
Pulse generator
PLL error amplifier
PLL phase detector
Series regulator 1
J3 SCR macromodel
