davicente
Junior Member level 3
Hello, my name is David.I`d like to know if the frecuency stability of the output signal in a PLL is the same as in the clock reference used in the loop.I mean, if the reference clock is 4 PPM, and the PLL has a multiplication factor x15 to obtain a 300 MHZ output signal, has this output signal also a frecuency stablity of 4PPM?does the PLL only make the phase noise of the output signal get worse?
I`ll be deligthed to know any link to application notes or articles related with this toipic.
Thanks in advance
Thanks in advance
