FPGA Power On Reset Circuit Actel AX2000
It's an FPGA, pick a pin and use it as the reset. The reset is just another input pin and an internal net. Now how you design your reset scheme is another thread altogether.
Reactions: rhnrgn
    rhnrgn
:D i am newbie, only part of my job is hardware not embedded design, and also this is my first FPGA hardware design and i wanted to be sure.
Just pulling an I/O to high or low is enough? This is very interesting for me as a MCU circuit designer hahaha.
Thanks mate.
Depending on the internal function of the reset signal, you'll usually want a reset synchronizer that releases the reset synchronously to the design clock. Otherwise the reset effect may have unpredictable results.
Reactions: rhnrgn
    rhnrgn
Basically in FPGA there wont be any dedicated RESET pin. You can use any pin as reset but make sure at power on you need to give a reset pulse. You can connect this pin to any of your controller , if you have in your board. Better discus with your firmware team, how do they want this reset.
Amit
Reactions: rhnrgn
    rhnrgn
