FPGA Look-up tables and Muxes
journeyman200
Newbie level 3
Newbie level 3
So I need to build a 8 to 1 MUX with any number of 4-input look up tables. The structure of the LUT is similar to this LUT.jpg but with the extra select bit and 8 extra values.
The answer I was given is to turn the LUTs into 2:1 muxes and use 7 of them. 4 to contain the values, 2 to select between the 4 muxes, and 1 to select between the 2.
However, I'm confused because isn't the LUT basically a mux? It's a 4-input LUT so it has 16 possible values, which is more than an 8-1 mux has. So why can't I just use 1 LUT?
Thanks for any help.
