mhezekiel
Newbie
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity HC_SR04_Distance_Measurement is
port (
clk : in std_logic;
reset : in std_logic;
echo : in std_logic;
distance_out : out std_logic;
led_out : out std_logic_vector(3 downto 0); --- LEDs output
trigger : out std_logic
end HC_SR04_Distance_Measurement;
architecture Behavioral of HC_SR04_Distance_Measurement is
-- Constants
constant CLK_FREQ : integer := 50000000;
constant TRIGGER_INTERVAL : integer := 10000000; -- 200 milliseconds
constant TRIGGER_PULSE_WIDTH : integer := 500; -- 10 microseconds
constant CM_DIVISOR : integer := 58;
-- Signals
signal counter_trigger : unsigned(23 downto 0) := (others => '0');
signal counter_echo : unsigned(15 downto 0) := (others => '0');
signal distance_cm : integer range 0 to 255 := 0;
signal led_toggle : std_logic_vector(3 downto 0) := (others => '0');
signal trigger_pulse : std_logic := '0';
begin
-- Output distance threshold
distance_out <= '1' when distance_cm <= 40 else
'0' when distance_cm >= 140;
-- Connect LED toggle to output
led_out <= led_toggle;
-- Connect trigger pulse to output
trigger <= trigger_pulse;
-- Trigger pulse generation
trigger_pulse_gen: process(clk, reset)
begin
if reset = '0' then
counter_trigger <= (others => '0');
trigger_pulse <= '0';
elsif rising_edge(clk) then
-- Increment the counter
counter_trigger <= counter_trigger + 1;
-- Generate trigger pulse
if (counter_trigger = to_unsigned(TRIGGER_INTERVAL, counter_trigger'length)) then
trigger_pulse <= '1';
elsif counter_trigger = to_unsigned(TRIGGER_INTERVAL + TRIGGER_PULSE_WIDTH, counter_trigger'length) then
end if;
end if;
end process;
-- Echo pulse measurement
echo_pulse: process(clk, reset)
begin
if reset = '0' then
counter_echo <= (others => '0');
distance_cm <= 0;
-- Measure echo pulse width
if echo = '1' then
counter_echo <= counter_echo + 1;
elsif echo = '0' then
-- Calculate distance in cm using shifts
distance_cm <= to_integer(((counter_echo * 1000000) / CLK_FREQ) / CM_DIVISOR);
end if;
end if;
end process echo_pulse;
-- LED toggle for out of range
led_toggle_gen: process(clk, reset)
begin
if reset = '0' then
led_toggle <= (others => '1');
if distance_cm > 255 or distance_cm < 20 then
led_toggle <= not led_toggle;
else
end if;
end if;
end process;
end Behavioral;
The above VHDL code is for the ultrasonic sensor. The aim is for the FPGA board to output 'high' when the measured distance is less than or equal 40cm and 'low' when its greater than or equal 140cm. I also incorporate in the code to toggle 4 LEDs if the measured distance is out of range which is 0 -255cm
After programming the ultrasonic sensor, I want the same to be done for the pressure transducer to output high or low at set thresholds
Can the above code carry out the tasks? If no please help me with a clue
