ku637
Hello,
I'm looking at an FPGA design, whose clock (differential) data sheet specification (Table 54 ) has mentioned rise / fall time typical value as 200ps. ( only typical value is available)
The design is using a crystal clock source ~120MHz ( single ended) and use a Differential driver whose output specification says rise/fall time spec as Min:200ps, Typ: 500ps and Max:1ns
I'm doubtful as why the FPGA specification doesn't state maximum spec for rise time in this case or is it just like higher values of rise time is acceptable.
Will this be a problem in this case if the FPGA max rise/fall spec is <1ns. Any thoughts?
