FPGA CASE When Hex range data syntax
What is the syntax for a range of Hex values e.g. When = X"03" to X"F9"?
  • When = X"03" to X"F9"
    Votes: 0 0.0%
  • or When = X"03 to F9"
    Votes: 0 0.0%
  • Total voters
ralphLunt
Newbie
Newbie level 2
Syntax for range of Hex values in the when line of a CASE statement.
e.g. When = X"03" to X"F9" => ....
Thanks
I did not understand the question. Specifically how the sentence in English is formulated.
Thanks
This is the code I'm evaluating for syntax
Case Sel is
When = X"03" to X"F9 => code to execute
When others .....
What is the correct syntax for the line above X"03" to X"F" , or X("03 to F9", or another format
Code VHDL - [expand]
case sel is
  when X"03" | X"04" | X"05" | X"06" | X"07" | X"08" | X"09" | X"0A" ......etc
when others .....
If you have such a huge range of values you are testing against it is probably better if you use an if statement
if sel >= X"03" and sel <= X"F9" then
end if;
You didn't mention the type of sel. The case statement can use discrete ranges with "to" in the choice, but only for integer case expressions.
If sel is e.g. an unsigned type, you can write
case to_integer(sel) is
  when 16#03# to 16#f9# =>
  when others =>
end case;
Similarly, you can cast std_logic_vector case expressions to_integer(unsigned( )).
