Fourier Transform of a Gaussian Pulse...????
aryajur
Advanced Member level 3
San Jose, USA
fourier transform gaussian pulse
What is the fourier transform of the gaussian pulse:
f(t) = A exp(- a(t-to)²)
Any references or help would be appreciated !
gaussian pulse fourier transform
Find a book - any book, which has the Cauchy problem of heat equations. There is a standard way to deal with the Fourier transform of this type of functions. You'll see that everything boils down to an integral which can be calculated by differentiation under the integration. If you care, it is actually a very good exercise of your calculus.
fourier transform of gaussian pulse
The Fourier transform of a Gaussian Pulse is a Gaussian pulse.
See the file attached.
I hope I have helped
    aryajur
fourier transform of a gaussian pulse
Yes I finally found the transform, from google. Thanks !
hi
fourier(exp(-t^2))--------------->pi^(1/2)*exp(-1/4*w^2)
bye
gaussian pulse
It is well-known that FT of a Gaussian pulse will give a Gaussian in frequency domain. My question is that if this Gaussian pulse is unique? In other words, if there exits other pulse shapes that will also give identical shapes in frequency domain?
This question has puzzled me for some time. Anyone here knows the answer from the top of your head? Thanks.
