jugemu1234
Newbie level 5
ring vco
Hi all,
I've been trying to downsize the volume of VCO noise at 3GHz use.
According to spectreRF (MMSIM7.0.1) pss+pnoise analysis for VCO only, higher Kvco gives same phase noise over entire offset.
But I believe higher Kvco should bring worse phase margin since noise sensitivity gets higher.
Could anybody explain what is going on? Am I misconfiguring Or is this happening because of the fact with ideal Vctrl?
Thank you very much in advance.
Hi all,
