kaiserschmarren87
Member level 4
Formal port/generic <> is not declared in--- ERROR!
Hello,
In the design which I am working on, I need to pass a std_logic_vector(15 downto 0) from a register in the top module to an input port of a sub module. I have done it in the following way:
During Synthesis I get this error "Formal port/generic <configmem> is not declared in <sub_module_2>.....
I am routing the value correctly I guess.
I get this error when I have either top module is set as top module or sub_module_1 set as top module....
I am using Xilinx ISE 14.3 version.
Is there anything missing or wrong in port mapping method?
I got the solution... Just had to declare the components for the respective modules....! Simple mistake though...
Hello,
-----top_module----
signal ConfigMem_Wire : std_logic_vector(15 downto 0);
{Register_module}
register => ConfigMem_Wire
{sub_module_1}
ConfigMem => ConfigMem_Wire
-------sub_module_1-----------
ConfigMem : in std_logic_vector(15 downto 0);
ConfigMem_Wire <= ConfigMem ;
{sub_module_2}
-----------sub_module_2--------------
{sub_module_3}
{sub_module_4}
{sub_module_5}
Hello,
Code:-----top_module---- signal ConfigMem_Wire : std_logic_vector(15 downto 0); {Register_module} register => ConfigMem_Wire {sub_module_1} ConfigMem => ConfigMem_Wire -------sub_module_1----------- ConfigMem : in std_logic_vector(15 downto 0); signal ConfigMem_Wire : std_logic_vector(15 downto 0); ConfigMem_Wire <= ConfigMem ; {sub_module_2} ConfigMem => ConfigMem_Wire -----------sub_module_2-------------- ConfigMem : in std_logic_vector(15 downto 0); signal ConfigMem_Wire : std_logic_vector(15 downto 0); ConfigMem_Wire <= ConfigMem ; {sub_module_3} ConfigMem => ConfigMem_Wire {sub_module_4} ConfigMem => ConfigMem_Wire {sub_module_5} ConfigMem => ConfigMem_Wire
