superluminal
Member level 4
- Joined
- Jan 31, 2002
- Messages
- 79
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Inside a quantum well
- Activity points
- 806
uo=350 phi=0.9 vto=0.7 mj=0.45
Well, it was my first time trying pole zero analysis using HSPICE. then I select a very simple "academic " CMOS CS amplifier. Even I used LEVEL 1 model to make things no easier. My netlist was :
PZ trail : CS
.OPTIONS LIST NODE POST
.OP
.AC DEC 100 1K 100G
.PZ V(VOUT) VS
.PRINT AC
VDD VDD 0 DC=3V
VS VS 0 DC=0.867V AC=0.707mV
M1 VOUT VS 0 0 NMOD L=2u W=30.64u
M2 VOUT VG2 VDD VDD PMOD L=4u W=13.94u
M3 VG2 VG2 VDD VDD PMOD L=4u W=13.94u
IREF VG2 0 DC=37.65uA
.MODEL NMOD NMOS
+LEVEL=1 VTO=0.7 GAMMA=0 PHI=0.9 NSUB=9.0e+14 LD=0.08e-6 UO=350 LAMBDA=0.14 TOX=9e-9
+PB=0.9 CJ=0 CJSW=0 MJ=0.45 MJSW=0.2 CGDO=0.4e-9 CGSO=0.4e-9 JS=1e-8
.MODEL PMOD PMOS
+LEVEL=1 VTO=-0.8 GAMMA=0 PHI=0.8 NSUB=5.0e+14 LD=0.09e-6 UO=100 LAMBDA=0.07 TOX=9e-9
+PB=0.9 CJ=0 CJSW=0 MJ=0.5 MJSW=0.3 CGDO=0.3e-9 CGSO=0.3e-9 JS=0.5e-8
.ALTER
R1 VS VG1 180K
M1 VOUT VG1 0 0 NMOD L=2u W=30.64u
.END
For the first case ,R1=0, I should get only a pole at f=65.18 M & a zero at f=5.82 G (by hand).
But HSPICE gave me :
poles (rad/sec) poles ( hertz)
real imag real imag
-234.2986x 0. -37.2898x 0.
-647.3471x 0. -103.0285x 0.
zeros (rad/sec) zeros ( hertz)
real imag real imag
-386.5422x 0. -61.5201x 0.
35.5751g 0. 5.6620g 0.
& for 2nd case , I should have 2 poles : 0.89 M & 65.18 M & a zero at 5.82 G. But I got
real imag real imag
-5.3817x 0. -856.5288k 0.
-369.3320x 0. -58.7810x 0.
-2.6527g 0. -422.1972x 0.
real imag real imag
Well, if you run this & see the frequency response (mag & phase) you will see only the poles and zeros you excepct by hand caculations.
If anyone can help, I will be so glad.
PZ trail : CS
.OP
.AC DEC 100 1K 100G
.PZ V(VOUT) VS
.PRINT AC
VDD VDD 0 DC=3V
.MODEL NMOD NMOS
.MODEL PMOD PMOS
.ALTER
R1 VS VG1 180K
.END
real imag real imag
real imag real imag
real imag real imag
real imag real imag
