Footprint Problem with OrCad and Protel
kirschi
Newbie level 5
Newbie level 5
Hi all!
I have a problem with the footprints in protel and OrCad.
I have done a conversion from my OrCad386 Schematics, PCB's and Libraries to OrCad dsn (9.2), Protel, Altium and Pads Flow.
Opening a Schematic and PCB's is not a problem.
In OrCad386 there are no "footprints", but "First part field". I copied the content of First part field to "footprints" in OrCad and imported the *.dsn file to Protel.
At importing a *.dsn into Protel, i get this Error/Warning-Message:
         OrCAD Capture Import Log:
            Current document: Imported APO1000.DSN\APO1000.SCH
               Warning: SheetPath of part at (490,840), changed from to _1
               Warning: SheetPath of part at (490,770), changed from to _2
               Warning: SheetPath of part at (340,730), changed from to _3
               Warning: SheetPath of part at (300,690), changed from to _4
               Warning: SheetPath of part at (500,690), changed from to _5
               Warning: SheetPath of part at (230,690), changed from to _6
               Warning: SheetPath of part at (200,850), changed from to _7
           Imported with warnings!
         EndLog
>> What does that mean?
Now when i want to create a netlist from my schematic, it gives me the following:
D1
DIODE75
1N4007
R2
RC07
1K2/1W
REL1
10DIP300
TQ2-24V
T1
SWKA2000
KATAST
X1
14SIP100
STOKO14
X2
STOKO3
STOKO3
X3
STOKO3
STOKO3
X1-7
X2-2
X3-2
ANK
REL1-3
X1-8
X2-3
G+
D1-CATH
REL1-10
T1-3
X1-13
G-
D1-ANOD
REL1-1
X1-3
NetT1_2
T1-2
T1-4
NetT1_5
R2-2
T1-5
NetT1_6
T1-6
T1-8
R+
T1-7
X1-5
R-
R2-1
X1-1
SIG
REL1-4
X3-3
T1
T1-9
X1-2
T2
T1-10
X1-4
X2-1
X3-1
Is this a good/working Netlist?
To create a PCB from it, i read that i have to load all my libraries into Protel, create a new PCB-Document and load the netlist. When i do that i only get two resistors in my PCB-Layout, and they're not connected either.
Does anyone of you know where i can search for a mistake or error?
If you need any further information regarding the schematic or pcb, please let me know.
Thank you in advance, i appreciate your help very much!
Best regards, Walter
generate netlist like that tools-->create netlist-->others-->in that select orprotel2.dll from for-matters (before that you need fill the Protel PCB footprint )
if you convert schematic from orcad to protel i have not any idea about netlist
Hi!
Thanks for your help, that has already brought me one step further.
Now i'm facing a new problem.
When i want to load the netlist into the PCB-Layout (Protel99SE), the following errors occur:
ACTION: Add new Component D1 ERROR: Footprint DIODE75 not found in Libary.
This happens for all Devices except the two resistors in my circuit.
As i converted the Libraries from OrCad to Protel, i have a Question: Are the "footprints" of the components stored in the SCHEMATIC- or the PCB-Library?
Because Protel wants to load them from the PCB-Libs, and i think they are stored in the SCHEMATIC-Libaries.
Am i right?
Thanks for your fast help!
best regards, Walter
Hi, can u give me an advice how to do that? i'm new to orcad and protel.
Normally i just do eagle layouts, thats way easier than this!
EDIT: I just figured out, that my PCB-Libraries don't contain the Footprints for the components i want to import there.
Thats weird, because the Libraries come from OrCad386, and there everything worked perfekt.
Now the question is, how do i put these back in? where are they stored normally?
Thanks!
Hi ,
please follow below method,
1.open your schematic file and then select project manager then edit-->Browser-->Parts or select schematic Right click edit Properties (new window open select the pcb footprint ,enter the protel footprint )
2.new window popup, select reference column (new window has reference,Value,Page,Source part ) Ctrl+E -->Browse spreadsheet open,enter the Protel footprint in PCB footprint.
3.Generate protel netlist
4.give the footprint path in your protel software (i don't know protel)
Hi, i just solved my problem. Fortunately i had the finished *.pcb file, which i converted to a libary and loaded into the PCB-Libraries.
Thank you for your help.
Me Again,
now i have a final problem. I need to convert my schematics and PCB's to pads
flow that another person can work with it, and then i have to convert it
back
FROM PADS FLOW TO ALTIUM/PROTEL/ORCAD.
Does anyone of you know whether this is possible?
It would help me very much!
Regards, Walter
