footprint in Allegro
Unzip the downloaded file.
Run the .bat file in that. Before that set psm and pad path in your .dra file in advance.
Thanks, I Run bat file . it just show pad , Finally , should I make a dra file ?
Before going to run .bat file do the following
Just open the empty .dra file and set the psm and pad path.
Move the unzipped file to the location which u mentioned for paths.
Run the .bat file.
It will work.
