Footprint for Oslon Square GW CSSRM2 LED
T
treez
Newbie level 1
Hello,
We are doing a footprint for the Osram “oslon square” GW CSSRM2 LED.
It will be mounted on IMS PCB. We wish to have a big thermal copper area connected to the pad. Page 15 of the datasheet gives some pad recommendation........but does not state the entire copper dimensions. They give copper recommendations for approximately an area of 6mm x 6mm.
What we wish to know is, is there likely to be any restriction to the placement of thermal copper beyond that approx 6mm x 6mm area shown?......or can copper be placed anywhere when beyond that 6mm x 6mm area?
Oslon square LED
https://dammedia.osram.info/media/resource/hires/osram-dam-5563433/GW CSSRM2.PM_EN.pdf
Copper Areas I think are for cooling purpose.So, I guess these copper areas can properly be placed anywhere connected to main PADS...( If there is no area constraint )
Reactions: treez
    T
The copper is there to take away the heat from the component, the more, the better. But it is always limited by the placement space on the board
In this case I would build the component footprint according to the data-sheet with the 36mm² copper area. In this way you meet the requirement of the manufacturer.
During layout you can add extra copper when space allows this.
Reactions: treez
    T
