yolco
Member level 2
I'm just trying to design the footprint for a QFN Component.
The pins, thermal pad, vias, oard geometry, package, etc are already placed, but when thermal pad is placed over the vias (which is the right place for them), DRC error 'SMD Pin to Thru Via Spacing' is shown in every via.
If I show the element the message is:
Could someone help me to solve the issue, please?
Also, it would be helpful an explanation about it to understand it in a better way.
KR!
< DRC ERROR >
Class: DRC ERROR CLASS
Subclass: TOP
Origin xy: (-2.450 -2.450)
Constraint: SMD Pin to Thru Via Spacing
Constraint Set: DEFAULT
Constraint Type: NET SPACING CONSTRAINTS
Constraint value: 0.1 MM
Actual value: OVERLAP
Element type: STAND-ALONE PIN
Class: PIN
(0.000 0.000)
Element type: VIA
Class: VIA CLASS
origin-xy: (-2.450 -2.450)
not on a net
Number of connections: 0
Padstack name: Component_VIA
Type: Through Plated
Circle_drill : 0.200
padstack defined from TOP to BOTTOM
rotation: 0.000 degrees
Via is not mirrored
KR!
