cjupiter
Member level 2
folded cascode op amp
Here is your standard fully diff. folded cascode op amp. Im using 0.18um technology, 1.8V supply. Im not getting the correct open loop output. My open loop gain is way tooo low. Cant even get a gain of 1. I know that all transistors should be operating in the saturation region. How do i go about setting all transistors to be in saturation? Do i set my bias voltages first and then adjust the W\L ratios? Its becoming a real nightmare to get this opamp working. Can anybody point me in the right direction. I have access to most analog circuit design texts if anybody wants to reference them. I have also attached my CMFB circuit.
Please Help!!
Please Help!!
