FM strength Measurement??
buts101
Full Member level 3
Full Member level 3
I want to build a simple strength meter which can measure the signal
strength of FM stations in my city(different places in the city) for project, which is in a week.
So, please help me with the circuit and tell me how can i display the
strength reading digitally. Please tell me how can i vary the frequecy
so that i can measure the strength for different FM stations.
You will need to build or buy a portable FM broadcast receiver. Then there should be some output from one of the IC pins that is the log of the signal strength. Then makd a digital volt meter with an ADC.
Why is there a log output from the IC? Is it an inherent part of the FM demodulation?
It is usually built that way so that the signal strength meters have a wider dynamic range.
