It is a simple "regen" radio. It must be TUNED to one side of an FM radio station and have its regen adjusted high enough to work as a radio.
If you built it on a breadboard then the high capacitance between the rows of contacts and between the jumper wires causes it to be tuning to frequencies too low. Try it when the 5pf capacitor (the one parallel to the tuning capacitor) is removed.
Solder /fix a wire to point 11, when you touch it to point 9 , you should get a click in the ear piece, this tests, the last two transistors to a certain degree. Get you DVM/multi meter (on volts) and measure between Point 11 (the wire) and the junction of the 10K and 22K, feeding the first transistor, while doing this put your finger across the tuning capacitor, this should stop the first stage squegging and the current will rise so your voltage will fall. Once you have proved this the problem could be in the tuning of Vc and the coil. Try spreading the turns of the coil (12 turns air spaced about 15mm long?). Come and tell us how you got on.
Frank
+1The photo shows that a 0.8uH inductor is missing...
