akhilpaulv
Full Member level 2
- Joined
- Apr 20, 2013
- Messages
- 136
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Thrissur, India
- Activity points
- 2,051
The fact is that under the loop frequency you must modulate the crystal of the reference frequency, otherwise the modulation will be acncelled by the loop correction, while above the loop frequency you can modulate directly the VCO.
The balance pot is used to avoid chenge in deviation passing from low to high modulating frequency. Take care that if the circuit is not very well designed, you will have very sharp changes in phase of the modulating frequency at the crossover frequency.
At the end, do not use it, unless you have the proper instrumentation to tune it.
Better use a DDS and a fractional PLL.
Mandi
