Elizabeth Carli
Suggest FM modulation and Demodulation circuit with external Fc
i want a simple FM modulator and demodulator circuit with Fc=250kHz using 555 timer ic. Im unable to find working circuits on google.
Hi BrianI don't see what's wrong with using a 555 at 250KHZ. Personally I wouldn't because of it's stability but it's quite feasible to do it. I think people are immediately thinking FM means audio when in reality it can be anything from FSK to disk data recording to video.
Brian.
I see an oscillator but I do not see how changing the tiny capacitance of the transistor with a modulation signal will create useable FM.
This oscillator is usually used at 100MHz which is 400 times higher then the frequency swing is useable.
It is a 250khz oscillator. Its tuning and feedback capacitors are 1000 times the tiny capacitance of the transistor so FM at this low frequency will not work that way.Hi Audioguru
I suppose that you know how to use a cap multiplier ? and i guess that you know how to use varicap diodes . right ? thus , with adding some simple changes in that circuit , that is truly possible.
Hi againIt is a 250khz oscillator. Its tuning and feedback capacitors are 1000 times the tiny capacitance of the transistor so FM at this low frequency will not work that way.
EDIT: The tuning and feedback capacitors are one BILLION times (not one thousand times) the tiny variable capacitance of the transistor.
About 5 years ago , i built an FM modulator at 500 KHZ without any kind of capacitive diode and only with adding the source signal , to the emitter of the circuit which i've mentioned , variations of frequency were as good as i could see them with my oscilloscope as well . so 250KHZ is about half . it will work too , and if we add the capacitive diode it will work much better too .I wonder where he will find an FM radio that operates at only 250kHz and with an FM deviation of almost nothing?
