FM modulating a simple PLL
vco96
Member level 1
Member level 1
FM modulating a pll
I'm not an expert in frequency synthesis, but it is possible to FM modulate a simple phased locked loop. The FM would have to be up to 20 KHz just for audio frequencies.
Thanks.
Re: FM modulating a pll
If the loop constant is fairly slow (long time to lock) you will be able to modulate the (vco) frequency without the loop losing lock. Attachment shows a typical design.
why not use the mixer?
Mixer ?
For Wide Band FM, how ?
If you FM modulate the reference oscillator would the pll still lock?
Thanks alot.
