tketke2002
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
transmit fm band
I wonder if someone has an idea how the implementation of a FM band transmit antenna can be done into a mobile phone.
Let's assume an available power of 1 mW while the required effective radiated power is roughly 100nW in the frequency range of 80 to 120 MHz.
The available volume is limited into a phone but the required efficiency is also low, although the antenna should be broadband from 80 to 120 MHz, if possible without tuning.
Any suggestions are very welcome,
tony
tony
