Flyback SMPS....NS/NP > 4.....so sandwich the primary instead to reduce leakage?
T
treez
Newbie level 1
Hello,
I am designing a flyback where there are more secondary turns than primary.
So, to reduce leakage inductance, is it ok if i "sandwich" a single primary layer between two secondary layers?
Re: Flyback SMPS....NS/NP > 4.....so sandwich the primary instead to reduce leakage?
yes, you can do so.
even spread wire across the entire bobbin, reduce dimension of coil.
Reactions: treez
    T
