Patrick_66
Member level 3
Hello everyone, wanted to ask how to obtain all the capacitance and resistance values in this paper as the datasheet for the IC did not mention how to get it as well as the paper. Hope that someone can help with that.
Hello Sir, the datasheet did not mention the capacitance and resistance value for the circled part (purple) based on the figure below. May I ask how to find all of those values? Thank you for your time.
Hello Sir, if I want my Vout to be 85 Vdc and Iout 0.4A which is the same as the specification given by the predefined transformer model 750811291. How do I know the range of value to adopt based on my defined Vout and Iout? Thank you Sir for your time.The schematic consists of several sections. Each has its function in the overall system.
Once you choose your desired voltage and current levels, those various sections tend to adopt a range of values that go with those voltage and current levels. This is done with both the power supply (input) and the supply (output) to the final load.
