Sunny55
Full Member level 3
I noticed that the output voltage from wall wart adapters are not constant(keeps fluctuating). If i apply that fluctuating voltage to a step down converter circuit, the output voltage from the converter circuit also fluctuates.
Fluctuating voltage is measured in no load condition.
How can i solve this problem? The step down circuit is an LM317 variable voltage regulator circuit.
Thanks,
Sunny55.
Thanks,
Sunny55.
