Float pkg is not working in VHDL
Soh_bhat
Junior Member level 1
Good day. I am trying to use float_pkg in VHDL, but it is throwing error " float_pkg is not compiled in ieee". I've tried ieee_proposed also but unfortunately it is giving the same error.
I tried using some fpu units from the internet but don't know how to use it in my code.
Can anyone help me with a glimpse of a code of how to use it?
Or, how can I use floating point do that the program is synthesized?
Actually i got the simulation using 'type' but while synthesizing it is not working.
Please help!
Hello,
show your code, please.
Best regards
Hi there, here's the code without float pkg.
Behavioural:
package pk5 is
 type T is range 0.0 to 50.0;
 type T1 is array (0 to 3) of T;
end pk5;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use work.pk5.all;
entity add is
   Port ( x : in T1 ;
          y : in T1;
          h : in T;
          x_o : out T1;
          y_o : out T1);
end add;
architecture Behavioral of add is
signal p, q : T1;
begin
process(x, y, h)
begin
p_o(0) <= x(_o0);
q_o(0) <= y_o(0);
addi: for i in 1 to 3 loop
p_o(i) <= p(i-1) + h;
q_o(i) <= q(i-1) - x(i-1);
end loop;
x_o <= p;
y_o <= q;
end process;
end Behavioural;
Test Bench:
library IEEE;
use work.pk5.all;
entity add_TB is
end add_TB;
architecture Behavioral of add_TB is
component add is
Port ( x : in T1;
          y : in T1;
          h : in T;
          x_o : out T1;
          y_o : out T1);
end component;
signal x: T1;
signal y: T1;
signal h: T;
signal x_o: T1;
signal y_o: T1;
begin
uut: add port map (
x => x,
y => y,
h => h,
x_o => x_o,
y_o => y_o);
add_proc: process
begin
 x(0) <= 1.0;
   y(0) <= 10.0;
   h <= 0.1;
  wait for 5 ns;
 end process;
 end Behavioral;
Here, using type it is running the simulation but it is not synthesized. Whenever I am using ieee.float_pkg.all or ieee_proposed.float_pkg.all, it is giving a red mark over there and its not running. I dont know how to change the code to make it synthesized.
I also downloaded some fpu unit from freecores/fpu_double, but don't know how to use it using VHDL code.
Please help!
maybe theses links be helpful:
Do you know this project (FPU) :
https://github.com/BrunoLevy/FPU
It is easy to understand.
Best Regards
    Soh_bhat
You don't specify what tool you are using or where you are seeing the error. Have you set the tool up in vhdl 2008 mode? Float pkg is only available from 2008.
I do not recommend using float pkg for synthesis code as it does not have any pipelining. Use available ip cores instead
I am using xilinx vivado 2022.1.
For the available IP cores, is there any possible way of using it? Like, are you telling IP catalog?
Yes, unfortunately you need to generate a core from the catalog, and then instantiate it in your VHDL code.
