OMEsystem said:Why bandgap circuit generates high flicker noise? the transistor flicker noise
will be amplified by core circuit of bandgap? Any intutive explanation?
eesoko said:Avoid any pinching-off of the transistors (i.e. insure that most of the current does not flow on the surface) and make them bit longer and you should be fine.
eesoko said:I usually do it by decreasing Vds and insuring that Vgb is high. This way I have both Vgs and Vgd relatively high, hence no pinching effect on either side of the channel. Unfortunately, in diode connected transistor you can not play with Vgd, so for current mirrors this will not work. You will have to play with current density.
There could be better ways too.
Good luck.
hoolish said:the normal way to reduce the flicker noise is just increase W*L.
