Flexlm license problem.
cyc
Member level 1
Member level 1
debussy license
In case I have more than 2 license files.
Can I just
setenv LM_LICENSE_FILE = license1.dat:license2.dat
and just run lmgrd for once?
I found my two license file would corrupt when the lmgrd is running.
Any answers are appreciated.
tcp port number debussy 27000
My currently solution is to login as two different users with different LM_LICENSE_FILE setting. Then excute lmgrd in each account.
set env lm_license_file point to license.lic
yes cyc,
I do the same...
Or if I'm win Win ME/9X - edit my autoexec.bat and reboot
Some programs requires different variables, and there are no problem...
lm_license_file flexlm
Hi cyc
1) Use ";" as delimiter between the file names instead of ":"
2) Use full path for the file.
Ex:- LM_LICENSE_FILE=C:\license1.dat;C:\license2.dat
good luck!
lmtools merge license
or:
setenv LM_LICENSE_FILE = {$LM_LICENSE_FILE}:license2.dat
flexlm on same server with different ports
You can join license files into one license file with text editor.
flexlm error -97 121
you can use
setenv LM_LICENSE_FILE license.dat:port@hostname
for lmgrd dameon. this creates no problem
setenv flexlm
Hi
Also you may have different LM_LICENSE_FILE´s depending on user,
because you have one for system variables and other for user.
so you may got server@port;somepath\license.dat;..... for each
and in the end they will sum.
Some old stuff requires the variable on user, others use the system fine.
license ncv
for floating licnese, you can point to your port@server one by one, or you can also uses licnese file.
for node-locked license, you can joint all of them into one file. then point to this file.
bug flexlm under windows server 2003
It sounds strange!
Here is a sample of my .cshrc file
setenv CDS_LIC_FILE /usr/local/packages/cadence/license.dat
setenv HLD_LICENSE_FILE 3228@?????.???.????.edu
setenv MGLS_LICENSE_FILE /usr/local/packages/modeltech/license.lic
setenv LM_LICENSE_FILE ${HLD_LICENSE_FILE}:${CDS_LIC_FILE}:${MGLS_LICENSE_FILE}:/usr/local/packages/avant/2000.2/license.lic
there is not any problem when running these tools (both nodelock and floating lics) on both Solaris machines and Linux machines. The same applies for my home server with many lmgrd versons.
cyc,
Can you please give us more detail about how it is corrupted then we can help you better.
:oops:
flexlm and lm_license_file
BTW,
lmgrd should run only once on the license server for floating lics does not matter how many clients are working on the entire network. Each user may have different LM_LICENSE_FILE env as long as it point to the correct port@server.
:oops:
set flexlm path
Your may merge this file in single with
dual DAEMON lines, but version lmgrd must be same.
Checkout your license file other use vendor daemon ?
If single merge this files
Checkout yor license file use other port number ?
If same change number port.
LM_LICENSE_FILE --- this string for checking, not for start
flexlm server delimiter
Hi hdang,
The following is my situlation:
1. When I set LM_LICENSE_FILE = "path of debussy's license file" only. The lmgrd works fine.
2. When I set LM_LISENSE_FILE = "path pf debussy's license file" : "path of ncsim's license file"
When I run lmgrd, I can't start the debussy's license daemon. I saw it is trying different PID. or sometimes reports multiple lisence daemon is started.
Both of the two license files includes server lines and daemon lines.
3. I login as two user account :
debussy: set LM_LICENSE_FILE = debussy's license file.
ncv : set LM_LICENSE_FILE = ncsim's license file.
Then, start the lmgrd at debussy account.
The ncsim doesn't need to run lmgrd.
It works.
Both of my server lines of license file use tcp port 27000. I wonder it is the root cause of this problem. But I haven't tried it.
flexlm cas license
Anyone has occurred the following case ?
Before installing one program, all existed tools work fine.
After installing one new software,
it modify the FLEXlm Manager setting automatically, and
the original workable tool can not work anymore :cry:
How to solve this problem ?
Thanks in advance.
ps: All these tools' license(s) as I mentioned are controlled by lmgrd.
ncsim license feature lmstat
cyc said:
Hi hdang,
It works.
You are right. The root cause of the problem is both daemons using the same tcp port.
Zoovy
lm_license_file
cyc,
If ncsim does not need to run lmgrd so it does not need the SERVER and DAEMON lines. You can remove them and run if it help (I do not think it is the case though!).
In the case of Debussy. U should do:
+ create the debussy license file with SERVER and DAEMON lines. Let's say debussy.lic (does not need to add this to LM_LICENSE_FILE env)
* run lmgrd -c debussy.lic -l log
+ examine log file to see if all the license feature is valid and the the license daemon for debussy are up (consult Flexlm user guide). Or you can do lmstat -c debussy.lic to see if all features are valid.
** setenv LM_LICENSE_FILE port@yourhostname:eek:ther_license_files
Then run debussy.
Notes that:
:oops: step * only need to run only once.
:wink: ** can be set different for each user but must contain port@yourhostname.
For more information you may read Debussy installation and Flexlm user guide.
how to release debussy license
I would say:
start lmgrd pointing to ONE license file (in case you have 2 license files using the same daemon and the same port,
merge them together)
each license file should use a different port number
after the lmgrd(s) are running you can set
setenv LM_LICENSE_FILE <port_num>@<hostname>:<path_to_lic_file>/license.dat: ....
and all your application sw will find it.
of course different vendors may use different env.vars like
CDS_LIC_FILE or MGLS_LICENSE_FILE ..... so its up to you .
flexlm license corrupt
If it is the port addr conflict problem, you can make them different by editing the port addr of your license files. The port adress field is an editable field inside license file. After editing this field the license file is still GOOD. BUT make sure each port address field inside the license file matching with the corresponding port addr you defined in the LM_LICENSE_FILE or whatever environment variables.
flexlm tcp port
hello,
u can solve this problem as follows...
lm_license_file=c:\flexlm\license1.dat;c:\flexlm\license2.dat;
any no of paths can be added....to the above...
in win xp there is no problem if this is done..but in win 98...change the properties of autoexec.bat..by setting things like (when u right click on aotoexec.bat then u have options called properties....then change these settings)
