flexlm error - :system clock has been changed
AndrewC
Newbie level 6
Newbie level 6
flexlm date reset
The flexlm return error :system clock has been changed.
How to fix it ?
flexlm reset clock
Modify all the files/directory date back . Some shareware can do this automatic . Search the internet .
my problem
I had this problem. First I removed the program that used the time license. Then I used Norton System Works which scanned the computer for files and registry information that were no longer needed by programs and I told it to erase them. Then I installed the program again.
search for freeware. flex is vey sensitive for clock changes
first detach your pc power. then remove the bios battery. this will reset the bios . some MBs have a jumper for this. the instyall your app again.
Re: flexlm system clock
possible solution is ..
