flat single pole response preferences for the op-amp
Junus2012
Advanced Member level 5
Italy
Hello,
In my circuit, I have the frequency response shown below, as you can see at the area near to unity gain becoming horizontally flat. However, my phase margin measurement is good and it is 71 deg.
this flat region is some hoe I am not comfortable with it because always people talk about single pole LPF response as an ideal case,
I have done the pulse response, the peaking is reasonable as you see below
I would like to have your discussion on it
Thank you for your help in advance
Regads
Show your schematics.
The flat region you mentioned is an LHP zero. You can see that by the increase in phase (and gain). If this is a two-stage miller compensated amplifier, it means that your zero is before the second pole. As you mentioned, this will affect your amplifier's settling behavior.
it is folded cascode class AB buffered opamp
I used the negative compensation attempting to increase the circuit gain bandwidth product (GBW), but only the unity gain frequency increase (UGB).
in my circuit I have now GBW = 150 MHz,
and for the UGBW = 250 MHz,
I think the GBW should be the important one right?
the circuit is like this below
the reference
You are probably not showing the resistors in series with the output stage miller capacitors (we can only guess). Cadence schematics are more helpful in this case. The whole freq. response will be important for the settling behavior, so if you want a single pole settling, you should have about -20dB/dec slope till you reach the 0dB point.
