vinayby
hi,
in a project which requires to download ,say, an Audio file from PC to a flash card.. and then playback independently..... FAT is a simple but v.bad way to go
But if JFFS2 is used...as far as the device is connected to LinuxPC then there are no problems.. but.... how easy or hard is it / and what effort it takes:
-> to read the data off the filesystem.. independently.. i mean with the embedded controller routines..(ie.. in order for the uC to read data on fs and output to DAC...)
I need to estimate this before i can startoff with the proj... it wd be great if someone could throw some light on this...
