hm_fa_da
Full Member level 5
I'm trying to make a flame detection device (for gas flame) by UV sensor. the distance between flame and sensor is as long as the temperature doesn't hit the sensor (1-2 meters maybe).
I searched and found UVTRON sensors by Hamamatsu :
https://www.hamamatsu.com/us/en/product/category/3100/3007/index.html
and some made devices by that sensor:
But these sensors need high voltage circuit which i don't want to use.
I found UV sensors like ML8511 or many other small and low voltage sensors (analog or I2C outputs) like:
https://www.mouser.com/Optoelectron...d-Sensors/_/N-6jju9?Keyword=uv+sensor&FS=True
I found many flame detection sensors (industrial shape) using UVTRON Hamamatsu sensors ...
What's the reason for this much usage of UVTRON ... ?!
Is there any limitation for using UV sensor chips (Like ML8511 or VEMEL6070 ...) ?
An important item is the reliability of the flame detector device, so is there any difference on this point between the above two different type sensors ... ?
