docdrew32
Newbie
Hello everyone,
First time post, long time viewer. I've been using Cadence's Innovus P&R tool for several years now, but have not noticed this irritating feature until now because my timing has always been able to close. However, it seems like every time i run a command or set of commands to fix the hold violations, Innovus decides to also insert additional delay cells and/or buffers on my setup paths, even if those are already passing static timing analysis (STA). I have been digging through documentation and have even started a case with Cadence, but was optimistic someone else out there has figured out what commands are necessary to just fix the hold violations without degrading the setup timing.
thanks
thanks
