Fixed frequency oscillator in verilogA
Ata_sa16
Full Member level 6
Full Member level 6
Milky Way Galaxy, 179° 56′ 39.4″
Hi all,
I am new to VerilogA and I have a code which I dont understand. Could you please explain this to me ?
Thank you.
// Fixed frequency oscillator
module osc1 (out);
output out; voltage out;			// output signal
parameter real freq=1 from (0:inf);		// output frequency
parameter real vl=-1;				// high output voltage
parameter real vh=1;				// low output voltage
parameter real tt=0.01/freq from (0:inf);	// transition time of output
integer n;
real next;
analog begin
    @(initial_step) begin
	next = 0.5/freq + $abstime;
    end
    @(timer(next)) begin
	n = !n;
	next = next + 0.5/freq;
    end
    V(out) <+ transition(n ? vh : vl, 0, tt);
end
endmodule
I dont understand this part
analog begin
    end
	n = !n;
    end
end
@(initial_step)
--> initialize the variable next to be equal to
next T/2 + the start time (the start time is not necessarily 0 based on if you set the tstart parameter for the transient analysis. T = 1 / freq)
@(timer(next))
-> Once the simulator reaches next (first time this happens is at T/2 + $abstime)
invert/toggle n (from 0 to 1 or vice versa)
increment next = next + T/2, i.e., by another half a clock cycle.
(timer loop will no be entered once clock reaches next + T/2 and redo)
Let V(out) transition to vh if n is 1 or to vl if n is 0 with a risetime of 0 and delay of tt s.
@(initial_step)
@(timer(next))
Thank you very much !
I tried to use this code for oscillator with jitter
`include "constants.vams"
`include "disciplines.vams"
module osc (out);
output out; electrical out;
parameter real fc=1.0e+9 from (0:inf);
parameter real Vlo=0, Vhi=1;
parameter real tt=0.01/fc from (0:inf);
parameter real fmJitter=0 from [0:0.1/fc);
parameter real pmJitter=0 from [0:0.1/fc);
integer n, fmSeed, pmSeed;
real next, dT, dt;
analog begin
fmSeed = 286;
pmSeed = 459;
next = 0.5/fc + $realtime;
end
@(timer(next + dt)) begin
n = !n;
dT = fmJitter*$dist_normal(fmSeed,0,1);
dt = pmJitter*$dist_normal(pmSeed,0,1);
next = next + 0.5/fc + 0.707*dT;
end
V(out) <+ transition(n ? Vhi : Vlo, 0, tt);
end
endmodule
and I did pss simulation in cadence to observe phase noise but I encountered an error
PSS analysis doesn't support behavioral module components with hidden states found in component
I use *ignore_hidden_states* in my code. This fixes the error but this time pss simulation does not converge.
ok,
convergence issues are always a bit tricky to deal with.
Possibly:
You could try to soften the transition a bit by introducing rise and fall times.
Also, how do you define dt? Probably initiated to 0, I presume, but maybe set dt to something before using it in timer(next + dt) in your initial_step part.
Further on, even through next is a big number compared to dt (i assume?) but still watch out for the next + delta_time becoming negative numbers.
Also - you have in analoglib a phase-noise generator (I think?) allowing you to generate a sinusoid with a phase noise spectral density mask definition. Maybe it's easier to use if you bump into too many convergence issues.
ok,
Possibly:
Thank you. I used the vsource in analoglib and you can define noise/frequency points.
