Fingerprint Authentication
bimbla
Advanced Member level 1
Which Fingerprint Authentication algorithm/ kit is the best? Several are offered. TI, Atmel, Authentek, FingerprintCards, Suprema are some of the few.
Is there anyone who is doing the projects on Fingerprint Authentication and has purchased kits?
Kindly share your experience.
bimbla.
You may refer to the following posts:
Besides, you may need this IEEE paper:
bimbla.
You should make difference between recognition algorithm and fingerprint scanner, because most of companies listed above offer only scanners.
Personally, I used FingerCell recognition SDK from Neurotechnologija Ltd. in some applications - it is really cool! The quality of recognition is perfect, even for bad quality finger scans. The SDK is quite cheap, supports most of finger scanners, can be used for mobile/embedded applications and easy to use. Check their site for details: www. neurotechnologija.com
Ace-X.
i wants to work on biometrics fingerprint and eyeris scanners
from where i should start and which controllers i should i use
which are the best fingerprint scanners to work on
and what are the cost of scanners/ kits and of which companies
i could get easily
