hi i would suggest you to go through the textbook 'J.-P. Colinge FinFETs and Other Multi-Gate Transistors' .It gives an insight of the nedd of finfet technology in the current scenario as well the complete modelling of the device.
If you look on IEEE or a similar site, you'll be able to find a lot of designs done in vertical gate processes. As far as references go for device physics of vertical gate FETs, I have a lot more than what I listed below, but these are my favorites:
K. Suzuki, Y. Tosaka, and T. Sugii, “Analytical threshold voltage model for short channel n+–p+ double-gate SOI MOSFETs,” IEEE Trans. Electron Devices, vol. 43, pp. 732–738, May 1996.
Y. Taur, “An analytical solution to a double-gate MOSFET with undoped body,” IEEE Electron Device Lett., vol. 21, no. 5, pp. 245–247, May 2000.
Y. Taur, X. Liang, W. Wang, and H. Lu, “A continuous, analytic drain-current model for DG MOSFETs,” IEEE Electron Device Lett., vol. 25, no. 2, pp. 107–109, Feb. 2004.
Z. Lu and J. G. Fossum, "Short-Channel Effects in Independent-Gate FinFETs," in IEEE
Electron Device Letters, vol. 28, no. 2, pp. 145-147, Feb. 2007.
P. Magnone, F. Crupi, A. Mercha, P. Andricciola, H. Tuinhout and R. J. P. Lander,
"FinFET Mismatch in Subthreshold Region: Theory and Experiments," in IEEE
Transactions on Electron Devices, vol. 57, no. 11, pp. 2848-2856, Nov. 2010.
S. D. Pable, A. Imran and M. Hasan, "Performance investigation of DG-FinFET for subthreshold applications," Multimedia, Signal Processing and Communication Technologies (IMPACT), 2011 International Conference on, Aligarh, 2011, pp. 16-19.
Lastly, as far as I'm aware, I don't have any layout tutorials/references that would be okay for me to share.
