Finding time period of an unknown signal
BojackHorseman
Newbie level 6
Newbie level 6
I want to find the time period of an unknown signal in microseconds. I already have a code that helps me find the frequency of an unknown signal. Is there a way to modify that code to find the time period of that signal in microseconds ?
`timescale 1ns / 1ps
module freq_counter( input clk_100mhz,
input reset,
input low_freq_clk,
output reg [13:0] out1
reg low_freq_clk_x, low_freq_clk_xx, low_freq_clk_xxx;
reg [25:0] lo_counter;
reg [26:0] hi_counter;
always @(posedge clk_100mhz or posedge reset) begin
  if (reset) begin
  lo_counter <= 26'd0;
  hi_counter <= 27'd0;
  out1 <= 14'd0;
  end
else begin
  low_freq_clk_xxx <= low_freq_clk_xx;
  low_freq_clk_xx <= low_freq_clk_x;
  low_freq_clk_x <= low_freq_clk;
  if (low_freq_clk_xxx & ~low_freq_clk_xx) lo_counter <= lo_counter + 1'b1;
  // Output total frequency when one second is up
  if (hi_counter == 27'd100000000) begin
    out1 <= lo_counter;
    lo_counter <= 1'b0;
    hi_counter <= 1'b0;
  end else
    hi_counter <= hi_counter + 1'b1; // Elapse time
end
end
endmodule
Basically if you have the frequency, then just do
t(p_us) = 1,000,000/f
But an unknown signal ... it can be anything...
At least you should specify
* the frequency range,
* the resolution,
* the update rate.
Klaus
* the resolution,
* the update rate.
Klaus
The frequency range is from 1000Hz to 9999 Hz. As for resolution I want the output in microseconds and update every 1 second.
and what about the "unknown" signal? How "unknown" is it?
In best case it is a clean square wave logic signal. Then the signal is not a at all unknow, just it´s frequency.
Or ist it any analog signal, or any modulated signal?
Klaus
@BojackHorseman
One cannot design a digital system where NOTHING is known about the system input/s.
The more information you give us, the more help will you get!
