[SOLVED] finding cutoff frequency of a bandpass filter from simulation curve
ashyma
Newbie level 6
Newbie level 6
I am very confused regarding the cutoff frequency:
i want to find the cutoff frequency of a bandpass filter from the simulation curve... lets say the gain is 41.8dB so what is the 3db cutoff frequency ? I have attached a curve for reference ,,, thanks
Your 3dB cutoff frequency is the frequency at gain 38.8dB (41.8dB - 3dB).
Reactions: ashyma
    ashyma
The cutoff frequency is when the output level has dropped -3dB which is 0.707 times the maximum amplitude and is half the output power.
Fred D. told you the lower cutoff frequency. You can see the upper cutoff frequency yourself.
Reactions: ashyma
    ashyma
Thank you every one
