finding a display with 0.65 inch digit height
hemnath
Advanced Member level 3
Chennai
i would require a display with a character height of around 0.65”. Attached is the reference images.
Can anyone please suggest any display.
Thanks in advance.
The reference is a custom made LCD display with special symbols and a bar graph. You won't find a similar display off-the-shelve.
4 digit 7 segment LCD displays with 17.8 mm (0.7") segment height are commonly used.
Thank FvM. I knew it is custom made. I was searching a relevant type LCD with around 0.65" height in the market.
Thanks SunnySkyguy. I cannot display the units in this type of display. That's the problem.
You cannot display the units with a standard 7-segment display. Also the original display doesn't display the units with 0.65" height, it has several smaller 13, 14 or 16-segment characters for it. Would you mind to explain your intentions clearly?
https://en.wikipedia.org/wiki/Sixteen-segment_display
