petervk
Hi all,
OK I know (a bit) about shielding sensitive circits from other sources of noise in the system, but what should I do about the circuits that generate the noise?
Should I be putting such things as LC filters on the supply TO the circuit thats going to be making a racket (to stop supply noise feeding back into the sensitive bits), or is it better to keep a path of low impedance on both supply and ground for the noisy bits?
Cheers,
Pete
Cheers,
Pete
