Filter Design (Power Supply Filter Design)
nareshgtr
Member level 3
Member level 3
Bangalore
Hi everybody,
Normally in Forward converter at the output side LC filter is used. In attached document schematic of Forward Converter is used. In that LC filter is used at the output side. Please can any body explain how to design output LC filter.
Regards
V. Naresh Kumar
What do you wish to know? How to calculate cut-off frequency? Quality Factor? Ressonance? Rippple? Or something else related to the Forward converter?
Explain your self better
I require following information
1. Inductor calculation
2. Capacitor calculation
3. Ripple
Regards
V. Naresh Kumar
Where did you get the rectifier design? Using a series inductor with a rectifier is a bad idea.
You should better refer to a known working circuit.
FVM,
thanks for your reply, please can give some information about how to calculate the output capacitnce of rectifier circuit.
Regards
V. Naresh Kumar
