Filter Design for broad band
rajesh navagare
Newbie level 5
Newbie level 5
Here, classical filter design method i know but i am not sure about filter design for following situation.
picture is given below for detail where 50 ohm is matched to capacitor and resistance load of 20 ohm, for band of 6 GHZ with center frequency of 5.5 GHz.
You can create a bandpass filter by putting in a series inductor. Or as an alternate there is a 2-capacitor bandpass. Perhaps it's not giving away too much if I post these...
These are merely two easy methods. By playing with values you might obtain the specified rolloff curve. Even then there could be a better method.
Wideband matching of a reactive load isn't generally possible. I don't see a way to achieve it in the present case.
Hello @rajesh navagare ,
For a properly filter design I think you would need 50 ohms in both ports.
Maybe a matching network is what you need.
I often use this calculator to simplify work:
You will need to know that 0.7pF are Z_c=1/jwC where w=2pif
BR
