Filter circuit for ASK Regenerative Receiver Module
leoren_tm
Advanced Member level 1
ask modul
anyway..dont have a reply if i have an output of 9800 or 4600 baudrate, can you suggest a filter circuit? because its to noisy!!!
ask module
that is naturally noisy because it operates on unlicensed frequency band which is similar to a crowded room, difficult to communicate, you have to add error detection routine to communicate successfully, i used similar module https://www.youtube.com/watch?v=yhoq1hGIG1Y
ask rf module software
could you share you experience on that module? any possible or suggestion for a design on the receiver part?(e.g antenna length, PCB routing)
Added after 7 minutes:
i guess what you did is filtering the data by means of software..right?
ask module
PCB routing and antenna length are not critical in its operation, most processing of proper data acquisition is done by software
    leoren_tm
a s k module
Thanks..thats all i need
another thing...do have some specs on it?
ask madule
very similar to that in your posted link only differ in brand
ask module ]
i just found that on net..but i dont have the datasheet...can you share what you have?
askmodule
this is the brand sold here in asia
modul ask
ah tnx...been to that site....im trying to search some app-note. for a stable system
