If 330E is 330 ohms then an opamp cannot drive it because this very low value resistor will draw too much current from the output of the opamp.
The TL072 will not work if the DC input voltage to R5 is less than about +4V because the opamp does not have a negative supply at pin 4.
Can't you see that the negative feedback resistor value at high frequencies is only 330 ohms? Then the output at 12V peak is 36.4mA which overloads the output of most opamps. Any load on this filter increases the output current.So I guess voltage followers will never work because their FB resistance is zero. And integrators won't work either.
The TL072 and most other opamps are spec'd with a minimum load of 2000 ohms.
