file modification code
smith_kang
Member level 5
Member level 5
hi all
I want to write a code in C such that it will erase the content of a file modified 24 hr before.
lets say i wrote file yesterday and if today i open this file it should be blank.file should be there contents should erase.
thanks in advance
hi,
can u clarify the exact OS on which u want this code ??
erase the whole file and create it again
you could open the file in write only mode i.e. "w" mode
for example
void main()
FILE *fp;
fp=fopen("c:\\mysoftwr\\trial.txt","w");
Added after 2 minutes:
pls note that while writing the filename the double back-slash is necessary
U can acess the file flags such as the date and time and attributes(hidden/readonly/system) from the C functions itself, I think ur purpose is solved
